12 years agoanalysis and optimization problem
Hello every body; During the analysis and optimization of my project on Quarts 12, I found that there are some registers are removed and the reason are " Stuck at GND due to stuck port data_in "...
12 years ago --- Quote Start --- Hello every body; During the analysis and optimization of my project on Quarts 12, I found that there are some registers are removed and the reason are " Stuck at GND due to stuck port data_in ", how can I prevent Quartus to remove these register. Thanks --- Quote End --- if your logic is always '0' then you don't need register.
