12 years agoAN638 with multiple Boards
Hi, I'm trying to use AN638 Reference Design to run on two boards (one to transmit, one to receive). I modified the packet generator to generate my own packets, and the packet monitor to recogn...
12 years agoAfter doing some more testing, it seems to be a problem with the XAUI-SFP+ board. I was able to use the HSMC loopback card and the 10G Mac was able to read those packets. However, after reconfiguring the project so that the data transmits from channel 2 of the board and receives from channel 1. This, however, causes the same issue as the two-board configuration.
Does anyone know how to go about debugging signals going through the HSMC board?
