14 years agoan error occurs during configuration(nSTATUS)
Hello all, Please help! We have a problem with cyclone III during configuration。My fpga used in AS and JTAG modes ,all the configuration pins are connected to the GND or VCC through ...
14 years agoThese problem has been solved,thanks~!
1、I don't try to program it in JTAG mode again for a period of time.Because I think the nSTATUS signal is not right. But to my surprise ,when I try program again ,it can be programed in JTAG mode now! Befor programed in JTAGmode, the nSTATUS is pulled low and high in cycles.After I program it in JTAG mode ,nSTATUS is pulled high steady. 2.Although , the AS mode still can't used at all. As the JTAG mode is right, I doubt the problem is occurs by EPCS16 . Erenow, I had replaced the EPCS16 by new ones for three times! Now, I decide replace the EPCS16 by a old one which had been used in other board. It can be work!!! Are the new EPCS16 I bought bad ???
