15 years agoALTREMOTE_UPDATE doesn't work with user logic
Hi All, Cyclone III issue. I've looked all over for an answer on this. I've written a boot Loader in VHDL which accepts a .rbf file via RS232 with an appended 32-bit CRC to verify a good tr...
14 years agoI wrote a state loop that sends the read params from all 4 "param" locations out the RS232 in ascii and figured it out by association.
Note: Nothing lines up with the data sheet. Once you see where stuff is then write the code accordingly. It does work well once you get around Altera's misleading data sheets.
