11 years agoALTPLL multiplication factor
Hi, I have 100 MHz clock source directly connected to FPGA (Aria V device), using this I want to generate 250 MHZ clock from FPGA. Is ALTPLL IP suitable for this requirement? Pls suggest. And a...
11 years agoJust to add that the PLL output frequency to the core logic might be lower than the external clock output. You may double check on the datasheet.
