11 years agoALTPLL multiplication factor
Hi, I have 100 MHz clock source directly connected to FPGA (Aria V device), using this I want to generate 250 MHZ clock from FPGA. Is ALTPLL IP suitable for this requirement? Pls suggest. And a...
11 years agoThe Arria V PLL output frequency can go up to 500MHz in the slowest speed grade for external clock output. So the 250MHz should not be an issue.
