kikoss
2 years agoALTLVDS TX IP - pin location constraints
Hello I Instantiated on my design an ALTLVDS TX module for agilex7 , and the compilation passed This ALTLVDS TX module output 4 differential ports (configured to 192Mbps each one ) + 1 diffe...
- 2 years ago
did you assign LVDS IO standard? Did you try to assign explicite pin locations for differential pairs? You only need to assign positive pins, negative pin will be assigned by fitter automatically.
kikoss
2 years agoHello
You right , need to set IO standard , seems quartus use default for ALTLVDS RX IP but not for ALTLVDS TX IP
Here is the standard I set :
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to CLKINP -entity safety_top_level
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to TX_LVDS_ADC_2P -entity safety_top_level
set_instance_assignment -name IO_STANDARD "TRUE DIFFERENTIAL SIGNALING" -to TX_LVDS_ADC_3P -entity safety_top_level
THX
