9 years agoALTLVDS Failing timing on simple interface
Hi I am failing timing implementing a simple ALTLVDS The clock speed is 200MHz the de-serialization factor is 2. I am interfacing a CYCLONE V SOC system to a two channel, 14 bit ADC (ADS4249) A...
9 years ago --- Quote Start --- Hi, Why are you using ALTLVDS IP? In my opinion this IP is not suitable for your needs. If I were you a would use simple DDR input registers with PLL. --- Quote End --- Hi Thanks. I think you make complete sense. I will try ddrio. Cheers Dave
