9 years agoALTLVDS Failing timing on simple interface
Hi
I am failing timing implementing a simple ALTLVDS The clock speed is 200MHz the de-serialization factor is 2. I am interfacing a CYCLONE V SOC system to a two channel, 14 bit ADC (ADS4249) ADC via LVDS I have 14 LVDS lanes in total to cover both ADC channels. Each lane does two bits. My problem is that Timequest is failing on setup time. I have not specified any constraints in my Timequest sdc for the LVDS. I am using Quartus 14.1. I notice that the megawizard greys out nearly all the options as soon as I select a deserialization factor of 2. Is this because ALTLVDS does not use PLLs for de-serialisation factors of 2? Please can anyone help me get my design through timing? Thanks Dave2 Replies
--- Quote Start --- Hi, Why are you using ALTLVDS IP? In my opinion this IP is not suitable for your needs. If I were you a would use simple DDR input registers with PLL. --- Quote End --- Hi Thanks. I think you make complete sense. I will try ddrio. Cheers Dave - Altera_Forum
