14 years agoALTGX reconfiguration with multiple pll clock inputs Error (21113)
I have a design on Stratix IV with an ALTGX transceiver (tx only) which can operate at different frequencies. I use the reconfiguration mechanism (i.e. ALTGX RECONFIG) to be able to switch between the different HSIO frequencies.
For this purpose, the ALTGX pll_inclk_rx_cruclk port is fed by two clocks from a pll instance: ALTGX INSTANCE: fpga_transceiver i_fpga_transceiver( ... .pll_inclk_rx_cruclk({w_fpga_pll_c1,w_fpga_pll_c2}), // input [1:0] ... PLL INSTANCE: fpga_pll i_fpga_pll( .inclk0( SMA_CLKIN_p ), .c0 (w_fpga_pll_c0), // .c1 (w_fpga_pll_c1), // Clock for first HSIO freq .c2 (w_fpga_pll_c2), // Clock for second HSIO freq .locked (w_fpga_pll_locked) ); The design does not compile, I have the following error: Error (21113): Signal "fpga_pll:i_fpga_pll|altpll:altpll_component|fpga_pll_altpll:auto_generated|wire_pll1_clk[1]" feeds the inclk[1] input port of the GXB transceiver PLL "fpga_transceiver:i_fpga_transceiver|fpga_transceiver_alt4gxb:fpga_transceiver_alt4gxb_component|tx_pll0", but the HSSI PLL can have only 1 direct cascade path from GPLL clock I would be most thankful if someone could help me fixing this issue!No RepliesBe the first to reply
