15 years ago
ALTGX for A2GX always outputs K28.5- ?!
I perform an RTL simulation (ModelSim) of an ALTGX transmitter-only for an Arria II GX. The transmitter is set to take a 20-bit input. I use Basic mode, 4 lanes unbonded. After I release powerdown and resets the proper way (see attachment), the PLL will lock normally.
The problem is that the ALTGX ignores the 20-bit data I feed to its input and goes on outputting over and over K28.5- (0101111100).
Help!
    The same problem with simulating altgx 3gb/s 1 lane 16bit+8b/10b basic mode transmitter+receiver cyclone iv gx.
    The receiver works fine after correct initialization procedure, transmitter do not. I have added pause, like you, but no success, it is in stuck state.
    The initializing procedure: (timescale = 1ps)
    initial begin
    		gxb_powerdown <= 0;
    		pll_areset <= 0;
    		rx_analogreset <= 0;
    		rx_digitalreset <= 0;
    		tx_digitalreset <= 0;
    	# 10000 gxb_powerdown <= 1;
    		pll_areset <= 1;
    		rx_analogreset <= 1;
    		rx_digitalreset <= 1;
    		tx_digitalreset <= 1;
    	# 1000000	pll_areset <= 0;
    		gxb_powerdown <= 0;
    		wait( pll_locked) repeat( 300) @ (posedge tx_clkout);
    		wait( ~busy) repeat( 3) @ (posedge tx_clkout);
    		wait( rx_freqlocked)# 4000000 rx_digitalreset <= 0;
    	end
    This - "wait( pll_locked) repeat( 300) @ (posedge tx_clkout)" do not help.
    There is no required pause in handbook's description.
    I have found a solution to my problem. On the contrary to what is told in the A2GX manual (Figure 4-3), tx_digitalreset must NOT be deasserted right after pll_locked goes to 1 but some delay must be added.
    I delayed 16 clocks (@ 100 MHz) tx_digitalreset deassertion after pll_locked goes high. The ALTGX now quits outputting K.28.5- and K.28.6- and starts outputting the real data I am feeding to it.
    Great that I found it, sad that, once again, I'm losing time fixing somebody else's bugs.
