Alterra Stratix IV Lot code
Hi Amin,
Well we built several boards that have this particular FPGA with the code ending in JOE & all of them have the same result on the flying probe test. They don't fail anything else. Like I mentioned the boards with the code ending in LOE, KOE, IOE all pass. We did try one of these failing boards on the functional test for the board & it failed with a "Not able to read FPGA firmware" so not sure if it got this fail message is because of the FPGA failing the flying probe test like I detailed in my first message. Is the code on the chip a lot code then? Please let me know.
Thank you,
Pete
Hello Pete,
The lot code from the picture you shared with me from the earlier post is S018AF77.
- AminT_Intel5 years ago
Is all of your questions addressed? I will leave close this case in 3 days if there is no further question from you.
- Pvalentino645 years ago
Amin so what is the code that ends in JOE then? Just wondering why those FPGA's measured differently. After further testing we did determine that the board that the FPGA's are installed on weren't affected when running a functional test.
Pete
Hello Pete,
The code that ends with 'JOE' is a trace code.
