INITDONE's avatar
INITDONE
3 years ago
Altera USB BLASTER is not recognized in device manager
USB Blaster is not recognized correctly in the device manager and it showing warning symbol. and device is not started with below error massage
Device USB\VID_09FB&PID_6001\91d28408 had a problem starting.
Driver Name: oem33.inf
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Service: AlteraUSBBlaster
Lower Filters:
Upper Filters:
Problem: 0x27
Problem Status: 0xC000007B
Can you please help me to resolve the Issue. I am using Intel Quartus 17.1 version , to resolve the issue I Installed / reinstalled and restarted the PC many times but it is not helping me to resolve the Issue.
and the below error massage on the general Tab on the device manager
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
{Bad Image}
%hs is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support. Error status 0x
Ramesh S
  • I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
  • ak6dn's avatar
    ak6dn
    What version/release of Windows are you using?
    Rather important to know this to help you resolve the issue.
    • INITDONE's avatar
      INITDONE
      Hi Ak6dn , Aiman
      while updating the driver for USB Blaster , I get the below error, may be the below error will help you to understand my issue.
      Thanks & Regards,
      Ramesh
    • INITDONE's avatar
      INITDONE
      I am using windows 10 version 21H2 .
      Ramesh
    • INITDONE's avatar
      INITDONE
      Hi Aiman , Ak6dn
      Thanks a lot for your help.
      Intel USB Blaster is working on windows 10 version 21H2 with Intel® Quartus® Prime Standard Edition Software version 21.1 drivers.
      Older software version also working with 21.1 drivers , just replaced the old driver folder with 21.1 driver and it is started working fine.
      Thanks & Regards,
      Ramesh S.
    • INITDONE's avatar
      INITDONE
      Hi Aiman,
      Thanks a lot for your reply, I am using Intel quartus 17.1 standard edition version, I tried this solution with Intel quartus 18.1 standard edition as well as Intel quartus 16.1 standard edition but still same error is occurring.
      If you have any driver which will resolve this issue please share , I will try with that driver.
      Please help me to resolve the issue .
      Thanks and Regards,
      Ramesh.
