Altera Remote Update IP core on Cyclone IV
Hello Luk,
1. If there is an error when loading the application configuration, how do I know ?
In the Parameter bit 000 will provide you the configuration CRC error , Any missing field in the configuration or mismatch will definitely trigger the CRC . Also you can use the watchdog timer as well for the same ;
If you refer the Figure 4 ; It is clear that in the code you can implement the Error count and try 3 times. Also In handbook below link; can you refer the configuration error section ;
To read the watchdog time-out value?
In the param , you can use the 010 , will give you the WDT timeout value ;
What is in the state register of param [111] ?
I am not sure I follow you here , According to RSU user guide it is illegal value .
Thank yo u,
Sree
Hello Sree,
Thank you for your prompt reply. Now I know how to operate it.
The parameter bit 111 in Cyclone IV or Intel Cyclone 10 LP devices performs the same function as the parameter bit 000 of other devices.
Thank you again.
