Roger_S
3 years agoAltera Quartus II 7.2 install program
We are updating an old design that uses the Altera EP2C15AF256C8N FPGA. It uses the Nios processor and was created using Altera Quartus II 7.2. As part of the upgrade debug process, we would like to ...
_AK6DN_
3 years agoEP2C15 is a CycloneII part, so it should be supported in QuartusII 13.0sp1 which is still available for download.
Upgrading to that still-supported version is probably the recommended approach.
If you absolutely positively have to get access to v7.2 that is not available for public download.
So you will need to contact Intel and open a case to execute an NDA, and they may or may not grant you access to a private download.
Me, I would bite the bullet and move to 13.0sp1.
- Roger_S3 years ago
Thanks for the suggestion, I may have to go with that option.
I contacted Intel, opened a case, and they sent me here, so it looks like that path isn't going anywhere.
