AGofs
6 years agoAltera PLL and Altera PLL Dynamic reconfiguration : choose C-counter for two outputs simultaneously.
Good morning, I'm working with Altera PLL/Altera PLL reconfig IP (Cyclone V). The input to Altera PLL is 160 MHz ,the outputs are 125 MHz each with difference of 225 degrees . Then I want to chang...
SreekumarR_G_Intel
6 years agoSure , thank you for the update , can you kindly close the case if there is no further questions ?
Thank you ,
Sree
- AGofs6 years ago
Yes, I think you can close the case....
