AGofs
6 years agoAltera PLL and Altera PLL Dynamic reconfiguration : choose C-counter for two outputs simultaneously.
Good morning, I'm working with Altera PLL/Altera PLL reconfig IP (Cyclone V). The input to Altera PLL is 160 MHz ,the outputs are 125 MHz each with difference of 225 degrees . Then I want to chang...
AGofs
6 years agoGood morning,
In order to check how Fractional N-PLL reconfiguration works at simulation , I've generated new project .
The project consists of PLL, RECONFIG_PLL and incoming/outcoming signals. PLL receives 160 MHz at its input and has only one output .
The initial output is 128 MHz, and then changes according to incoming data.
when I've used Fractional N-PLL, then simulation has stuck and stopped after 5000 iterations.
when I've used Integer N=PLL, then simulation works properly.
The TB is same for both N-PLL.
I'm working with ModelSim 10.5 Starter edition.
Why simulation of the Fractional N-PLL is sticking?
