15 years agoAltera PL-APU USB Master Programming Unit (Power supply ratings Help!)
Hi Folks, I just recently acquired an Altera PL-APU Master programming unit. (The USB version) I am wondering if anyone knows the Voltage and current rating needed for the DC Power supply...
15 years agoThere were no components at all near the DC input Jack. Only a small PCB with the rear connectors attached.
Then there is a small ribbon cable that connects this small connector PCB to the Main APU PCB. Which you can see in the image links I posted above. -Gerry
