15 years agoAltera PL-APU USB Master Programming Unit (Power supply ratings Help!)
Hi Folks, I just recently acquired an Altera PL-APU Master programming unit. (The USB version) I am wondering if anyone knows the Voltage and current rating needed for the DC Power supply...
15 years agoI took some HI-Resolution pictures of the Altera APU main PCB.
I did see some Voltage regulator components but I'm not sure how that determines the Proper input voltage. There are possibly several other circuits that do not use a voltage regulator and are connected to the same power supply input. Couldn't this potentially damage the circuits? I just wish Altera had it indicated the Voltage and current requirements in the User's manual. Such a pain in the Butt!! Regardless, Here are the Image links below: http://www.digital-circuitry.com/images/webpage/mylab/altera_apu_00b_%20012.jpg (http://www.digital-circuitry.com/images/webpage/mylab/altera_apu_00b_%20012.jpg) http://www.digital-circuitry.com/images/webpage/mylab/altera_apu_00b_%20014.jpg (http://www.digital-circuitry.com/images/webpage/mylab/altera_apu_00b_%20014.jpg) http://www.digital-circuitry.com/images/webpage/mylab/altera_apu_00b_%20015.jpg (http://www.digital-circuitry.com/images/webpage/mylab/altera_apu_00b_%20015.jpg) I also checked the underside of the PCB but there was no written text to indicate a voltage of any kind. If you can see anything on the TOP side of the APU PCB that may indicate a specific DC Input voltage please let me know. It would be greatly appreciated. Regards, Gerry O'Brien
