15 years agoAltera Modelsim problems
Hi All, I am a newcomer to VHDL having done a previous course using Verilog. I have a clock divider which produces one clock T-state-wide pulses from a 50Mhz system clock (say, every 10 milli...
15 years ago --- Quote Start --- SIGNAL Count : STD_LOGIC_VECTOR ((n-1) DOWNTO 0) := B"00"; SIGNAL Count2 : STD_LOGIC_VECTOR ((n2-1) DOWNTO 0) := B"0000"; Not elegant and there must be a better way of doing it --- Quote End ---
SIGNAL Count : STD_LOGIC_VECTOR ((n-1) DOWNTO 0) := (others => '0');
SIGNAL Count2 : STD_LOGIC_VECTOR ((n2-1) DOWNTO 0) := (others => '0'); --- Quote Start --- variable TenmsCntr : natural range 0 to 2**(n - 1) := 0; --- Quote End --- warning : It means 0 to 128 if n=8. That is surely not what you want. You are making an error, you should write variable TenmsCntr : natural range 0 to (2**n) - 1 := 0; -- means 0 to 255 if n=8 NB : You write too much. "Keep It Simple and St*pid" Happy to help you.
