14 years agoAltera Installer 11.1 Build 173, linux
Aloha, installer gives error right at begining, "Error connecting to the internet, check your proxy information ...." I'm connected to internet, no proxy needed. outgoing ip/icmp ip/tcp, ...
14 years agoIt seems that at least some of the Installer's executables, or the resolver library it's linked and distributed with are buggy; at least on my machine, Debian linux; wheezy/sid; 2.6.39-2-686.
In particular: ./bin/quartus_dl whom the installer uses as a littler helper for downloading from http. When quartus_dl resolves the IP for download.altera.com, it expects an ip, get's a CNAME, and then decides it's failed to connect. As a temporary solution I've used: echo "128.171.28.7 download.altera.com" >> /etc/hosts Now the installer seems to work.
