14 years agoAltera Installer 11.1 Build 173, linux
Aloha, installer gives error right at begining, "Error connecting to the internet, check your proxy information ...." I'm connected to internet, no proxy needed. outgoing ip/icmp ip/tcp, ...
14 years agoNo. dns doesn't seem to be the cause. to be sure, I created reverse entries in my hosts file for the missing in-addr.ptr records. And it still doesn't work.
The problem exists between these two system calls: [pid 1063] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7220000 [pid 1063] write(1, "DOWNLOAD_FAILED:4 | Error:IOErro"..., 88) = 88 mmap2 returned a pointer, so that worked, and yet the Installer decides that it's failed. Perhaps the content of the data mapped into memory was not what the installer expected. I think I'd have to unpack and debug the installer to pursue this issue any further. It's disappointing cause I really wanted to get some work done with my new FPGA kit this weekend. /juan.
