11 years agoAltera EP2C5 mini board clock pin
Hi. I tried the following example (Quartus II 13.0): module ledblink( input clk, output LED ); reg [23:0] cnt; always @(posedge clk) cnt <= cnt + 24'd1; assign LED =...
11 years agoQuartus will work out from your code what signals are clocks and what signals are not clocks. It is good practice to connect your 'clk' signal to a dedicated clock input pin.
A dedicated clock input pin can also be used as a general purpose input pin, for an input signal that is not a clock. That is all that the pin listing is telling you. So, if you were to add an input signal to your example as follows:module ledblink(
input wire clk,
input wire stop,
output wire LED
reg cnt;
if (!stop)
cnt <= cnt + 24'd1;
assign LED = cnt;
endmoduleThe input signal 'stop' could connect up to another 'dedicated clock/input' pin or any other user I/O pin. Cheers, Alex
