16 years agoAltera CycloneIII FPGA PLL problem
The PLL input clock is 27M. It is multipied and output a clock of 270M to supply the ASI IP core. 8 PCB boards are in test and downloaded the same FPGA program. The problem is, 4 out of 8 boards can ...
16 years agoThank you for your reply,dear std_logic_vector!
I have routed the input clock to an output pin and checked it.27M,the output clock is all right.So I think the problem isnot bad joints. The locked signal in faulty PCB is low,but the locked signal in PCB that can works well is also low.It is very strange.
