Mir's avatar
Mir
3 years ago
Altera Cyclone IV and USB Blaster
I am making an external programmer for Altera Cyclone IV (exactly EP4CE6F17C8N / EP4CE6F17I8N). I have a usb blaster. What is the minimum signal connection (JTAG) to program the circuit? I have connected:
VCCINT to 1.2V,
VCCA1 to 2.5V,
VCCA2 to 2.5V
VCCD_PLL1 to 1.2V,
VCCD_PLL2 to 1.2V,
VCCIO1 to 3.3V
GND,
GNDA1
GNDA2,
nSTATUS up 10k to 3,3V,
nCONFIG up 10k to 3,3V,
nCE to GND
USB Blaster:
TDI up 10k to 3,3V,
TCK,
TMSup 10k to 3,3V,
TDO.
Are these connections sufficient? I connected VCCIO1 to 3.3V so that JTG would work on these pins, but Quartus does not detect Altera. Do I need to connect anything else to be able to detect and program the system?
  • Mir's avatar
    Mir
    USB Blaster 1. I'm programming for the first time. Please let me know if this is enough. If so, and I haven't missed anything, I'll keep trying.
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
  • Hi,
    Are you using USB Blaster I or II? Did the USB Blaster ever work before with other board?
    Can you try to change to another USB Blaster?
    Aiman
  • Mir's avatar
    Mir
    I connected VCCIO6 to 3.3V and it still does not work.
    @Aiman,
    I saw this document, and from it I deduced what to connect. However, it's probably not enough, because there is still no connection
  • FvM's avatar
    FvM
    According to CIV handbook, you need at least VCCIO for B1 and B6, because configuration pins reside in B6. I presume you have also connected 3V3 to JTAG connector.
