user153746's avatar
user153746
4 years ago
Altera CPLD Max V (P/N: 5M40ZE64C4)
I am supplying this CPLD from two separate power rails (A 1.8V rail and a 3.3V rail). The CPLD uses 1.8V for VCCINT and VCCI02, and uses the 3.3V rail for VCCI01. The 1.8V rail starts up in about 1ms, and the 3.3V rail starts up in about 20-40ms. Will the component have issues since the two supplies are not coming up to voltage simultaneously?
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    AqidAyman_Altera
    Hi Liam,
    In the MAX V Device Handbook, under Power-Up Timing topic (page 3-9), it stated that the amount of time required from minimum value VCCINT (1.55V) to enters user mode is 200 microseconds for 5M40ZE64C4. You can refer to Figure 4-5 (page 4-6) for better understanding of power up characteristics of this device.
    AqidAyman_Altera
    Hi Liam,
    Thank you for reaching out to Intel FPGA Community.
    To answer your question, MAX V devices allow the device core and I/O blocks to be powered-up with separate supply voltages. . The VCCINT pins supply power to the device core and the VCCIO pins
    supply power to the device I/O buffers.
    When VCCIO and VCCINT are supplied from different power sources to a MAX V
    device, a delay between VCCIO and VCCINT may occur. Normal operation does not
    occur until both power supplies are in their recommended operating range. When
    VCCINT is powered-up, the IEEE Std. 1149.1 JTAG circuitry is active. TMS and TCK are
    connected to VCCIO and if VCCIO is not powered-up, the JTAG signals are left floating.
    Thus, any transition on TCK can cause the state machine to transition to an unknown
    JTAG state, leading to incorrect operation when VCCIO is finally powered-up. To
    disable the JTAG state during the power-up sequence, pull TCK low to ensure that an
    inadvertent rising edge does not occur on TCK.
    • user153746's avatar
      user153746
      Thank you for the help! One more question: The 1.8V rail (feeding VCCINT) comes up to voltage in about 300-900 microseconds. The data sheet for the CPLD does not state any voltage rise-time requirements. Is the given range ok for proper operation of the CPLD?
