8 years agoALTDDIO_OUT for clock output of chip
Dear all, i have an example FPGA configuration project for a FIFO interface. It is for a Cyclone 5 device and is comprised of a fifo interface, an ALTDDIO_OUT and a pll. The FPGA should act as mas...
8 years ago --- Quote Start --- Why not? Is not SignalTap telling me in relation to the sample-time at which point of time (sample) signals will be driven? The only problem I see is because of too low sample rates that the signal will be HIGH before the next edge tells me it is gone HIGH. Kind regards and thank you so far. --- Quote End --- Regarding sampling clkout in signaltap, the tool should tell you if that node is valid for signaltap or not. Signaltap can sample a signal at clock edge but can't tell you delay values in any resolution apart from clock resolution. If you are after tCO ...etc then you can't get that from signaltap but from timing report.
