17 years agoAligning a derived PLL clock with an external clock
Hello, previously i asked (http://www.alteraforum.com/forum/showthread.php?t=5439) about using a PLL to synchronize two clocks and received some excellent advice. My original question: ...
17 years agoZero delay changes the compensation of the PLL, but all outputs of the PLL get the same compensation. So whether you do zero delay or normal compensation, your 60MHz and 120Mhz can pass data without problem. (So probably go back to the default of Normal...)
