Shubhall
3 years agoAgilex not programming (E tile)
I am currently working Agilex FPGA (AGFB014R24B2E2V). For my design standalone GHRD I am able to program, but when I am adding the JESD example design to it, the following error is coming -
E...
ZH_Intel
3 years agoHi Shubhangi,
Thank you for your patience.
We could not replicate your error on our side and currently I am running some test to replicate it.
I believe there is a similar case ticket reported by you in below link:
Case - Not able to program Agilex FPGA
I would like to clarify with you is the case same issue? duplication of case?
If it is the same, I have provided you some input for you to try from your side.
However, I will paste the same answer here.
Thank you.
ZulsyafiqH_Intel
