IanD's avatar
IanD
3 years ago
Agilex In-System Memory Content Editor issue
Device: Agilex AGFB014R24B2E2V
Quartus version: Windows 23.2.0
I'm able to program the device through the "In-System Memory Content Editor". The Instance Manager shows two instances of type RAM/ROM that are Read/Write. When I right click and go to "Read Data from In-System Memory" the status says "Acquisition in progress". It stays in this state for some minutes until it times out.
Any idea what I'm doing wrong?
I have re-generated the ROM to make sure it should be accessible. See attached screenshot.
  • Problem is arbitration between the Quartus in-system memory editor and my logic accessing the memory. I need to halt the internal access so that Quartus has cycles to modify the memory.
    This is different than my experience on the Arria 10 devices.
  • SyafieqS's avatar
    SyafieqS
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
  • IanD's avatar
    IanD
  • SyafieqS's avatar
    SyafieqS
    Does that resolve the issue or still persist?
    • IanD's avatar
      IanD
      The issue still persists.
  • IanD's avatar
    IanD
    Thanks for the Response.
    I have tried power cycling and restarting Quartus to no avail. When I attempt to read the internal RAM, the JTAG connection is good.
  • SyafieqS's avatar
    SyafieqS
    Have you tried to resetting the FPGA board and reestablishing the connection? Normally it can resolve communication issues. Try power-cycling the board and restarting Quartus. Also make sure JTAG is connected properly to the device.
