kalidas
3 years agoAGILEX AGFB012R24B device configuration is not happening
Hi ,
I am trying to load an .sof file in to agilex AGFB012R24B fpga.The program contains only simple counter code .PMBUS ic is connected and sdm io pins are enabled accordingly.But the configuratio...
NazrulNaim_Intel
3 years agoHello,
You should check switch prog/run on your board. If use JTAG interface turn switch into run position, in the case using active serial programming you should choose prog position.
Hope that resolve your issue.
Nazrul Naim
