kalidas
3 years agoAGILEX AGFB012R24B device configuration is not happening
Hi ,
I am trying to load an .sof file in to agilex AGFB012R24B fpga.The program contains only simple counter code .PMBUS ic is connected and sdm io pins are enabled accordingly.But the configuratio...
Farabi_Altera
3 years agoHello,
please follow this troubleshooting guideline: https://www.intel.com/content/www/us/en/support/programmable/support-resources/configuration/troubleshooting.html
Checklist
Before you proceed to further debug your issue, you are advised to use this checklist to verify that you have followed the recommended configuration setup in your design.
- MSEL pins are tied to VCC or ground. Do not leave the MSEL pins floating.
- The nCE, nCONFIG, nSTATUS, CONF_DONE and dedicated JTAG pins (TCK, TMS, TDO, TDI) are connected according to the recommended setup in the device handbook. If pull-up/pull-down resistors are required, ensure the resistor values are correct.
- The power supplies are ramped up to the appropriate voltage level according to the device datasheet and are stable throughout the operation
- Ensure all the timing specification are met
Please check your design to make sure you follow below every configuration requirement using this debugging checklist: https://www.intel.com/content/www/us/en/docs/programmable/683673/23-1/configuration-debugging-checklist.html
regards,
Nazrul
