number_7
2 years agoAgilex 7 i series serdes capability
For Agilex 7 i series development kit (4x Ftile) transceiver data rate support is mentioned as 116Gbps at max. can i get any reference eye diagrams from intel, in order to verify the capability sup...
AR_A_Intel
2 years agoHi
Thank you for the update. Could you help verify whether FGT or FHT transceivers should be used? Please note that only FHT transceivers can achieve speeds of up to 116 Gbps, while FGT transceivers are limited to a lower data rate. It is important to choose the appropriate transceiver type based on the performance requirements of your design.
