TK99
1 year agoAgilex 5 LVDS Serdes (Serdes factor 7 and 504Mbit/s valid?)
Hello, I used A10 and C10GX devices to implement a LVDS Serdes with 504MBit/s and a 1:7 ratio. This is common interface towards LCD Panels (HD). We are looking forward to use an Agilex 5 device f...
TK99
1 year agoHi,
Thank you for your reply!
I need an 504MBit/s LVDS output (4 lanes and one for clock 504MBit/7).
For Arria10, Cyclone 10 GX and Agilex 7 were are LVDS Serdes Specs available to support this feature with a Serdes factor of 7 (internal clockrate 504/7) and a wide range regarding speed.
Right, the internal core frequency can be quite high for the A5.
But, The AC timing spec for Agilex5 has only Serdes factor of 4 or 8 and starting from 600Mbit/s (external).
The Spec for the DDR (Serdes Factor 2) Performance is given by 500Mbit (not 504)
The Agilex 5 LVDS Serdes Datasheet looks different to the Arria10, Agilex 7.
FvM
1 year agoHi,
you won't necessarily use DDR register for the SERDES design. I presume that a SDR fast clock of 504 MHz and slow clock of 72 MHz will be PLL generated and SERDES implemented in registers.
