SDavi9
1 year agoAgilex 5 FPGAs compatible with external optical transceiver
I have an external optical transceiver that states that it is compatible with the Ethernet 40GbE standard and InfiniBand QDR and FDR standards, which includes XLAUI, XLPPI, CPPI, and SFI interfaces. ...
RongY_altera
Contributor
1 year agoHi Shmuel,
Depends on your needs. For example, if you're planning a 40GE env, you can find the IP features here
1.1. Low Latency 40G Ethernet Intel® FPGA IP Supported Features
and supported FPGA here
1.2.1. Low Latency 40G Ethernet Intel® FPGA IP Device Family Support
Besides of these, you can create an example design and check IP settings to make sure it can enable some extra feature you may want in the future. You can find a comparison here. For example, if 1588 PTP is required, you may need to check Agilex 7 F-Tille.
8. Comparison Between Various Low Latency 40G Ethernet Intel® FPGA IPs
Rong
