KKlei5
1 year agoAgilex 5 design using DDIO shows clock routing failures
I have a simple design, trying to control some output pins using the Agilex 5 and GPIO Intel FPGA IP. The design is targeted for a new board design, but its so simple this could be done with the Ag...
sstrell
1 year agoAre you using the HPS? It looks like you are. How do you have the I/O peripherals set up in the HPS parameter editor? It also looks like you've created pin assignments in the Pin Planner. Is that where you've made DDIO assigments?
