Nicole04
1 year agoAgilex™ 5 EMIF IP for Hard Processor Subsystem (HPS) in Quartus 24.3.1
Good day, I had a working EMIF IP set up and connected to the HPS in Quartus 24.2. I then upgraded to Quartus 24.3.1 and now can no longer get the EMIF IP to compile without errors. I replaced the o...
sstrell
1 year agoYour screenshot is for your PD system, not the IP itself. You have to go into the IP parameter editor for the EMIF and there is an Example Design tab for configuring the example design and a button in the upper right to generate the example design based on the parameter settings.
