Nicole04
1 year agoAgilex™ 5 EMIF IP for Hard Processor Subsystem (HPS) in Quartus 24.3.1
Good day, I had a working EMIF IP set up and connected to the HPS in Quartus 24.2. I then upgraded to Quartus 24.3.1 and now can no longer get the EMIF IP to compile without errors. I replaced the o...
sstrell
1 year agoNo, I mean a customized example design you generate from the IP Parameter Editor that creates a whole project for you based on the settings you specify in the Parameter Editor. This is a good way to create a complete design quickly.
- Nicole041 year ago
Yes, I understand, but there is no option for this.
Is there a different path from which this can be done?
