srgp
3 years agoAGIB027R29A1E2VR3 programming issue due to PMBus
Hello, In our custom hardware we are using AGIB027R29A1E2VR3 device. while programming .sof we are getting following error. Error(18948): Error message received from device: External hardware acce...
Farabi_Altera
3 years agoHello,
I am sorry to keep you waiting.
I was confirming with experts and engineering if we can bypass the smarVID PMBUS signals.
Unfortunately, the PMBUS is compulsory for Agilex devices. The reason as below:
- The power requirement for each silicon is different.
- for example, the voltage requirement for one silicon, VCC is 0.8V, but the actual power required for this particular silicon is 0.8234V.
- This information on voltage required must be feedback to voltage regulator so it will provide the exact voltage to the device.
- This voltage requirement will vary between silicon but the range is still within the spec published in the datasheet.
- So PMBUS signal is compulsory for powering up the Agilex devices. If there is no PMBUS signals, the Agilex can't power up successfully.
regards,
Farabi
