KWang97
6 years agoAfter watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
FPGA communicates with another FPGA with PHY chip. Normally(watchdog enable checkbox not checked), the PHY link led is always off when communication is good. While after I enble watchdog for dual-con...
JohnT_Altera
6 years agoHi,
This is not possible if you are using POF file as it contain checksum for CRC checking.
May I know if you are able to update the UFM with the serial number after the POF is programmed? The reason is that I would recommend you to use JTAG Master and On Chip Flash IP to update the UFM with Serial Number so that it will be easier to be implemented.
