KWang97
6 years agoAfter watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
FPGA communicates with another FPGA with PHY chip. Normally(watchdog enable checkbox not checked), the PHY link led is always off when communication is good. While after I enble watchdog for dual-con...
KWang97
6 years agoHi,@JohnT_Intel
Thanks for your idea.
While there is a problem for us. The serial number will be set by workers in the factory ,then they can only program a file with serial number into FPGA. This will be done independently with the application pof. The worker in factory can't compile FPGA project and they can only do the programming with Jtag. So they just modify the file and download this file directly into UFM. So how will this be realized. Thanks very much!
