KWang97
6 years agoAfter watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
FPGA communicates with another FPGA with PHY chip. Normally(watchdog enable checkbox not checked), the PHY link led is always off when communication is good. While after I enble watchdog for dual-con...
JohnT_Altera
6 years agoHi,
This phenomenon is cause by the Max 10 being reconfigured. I would suspect that the reset watchdog timer is not being set. Not sure if you have a way to confirm that your state machine is executing the writing into the reset watchdog timer?
