After watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
I modified my code like below. Is this OK? But PHY communication still not work normally. Once I disable the " watchdog enable checkbox" it's OK while after enable it, it will not be OK. I reset watchdog only once at the initial state highlighted with bold character.
DualConfig0 : process( plClk )
begin
if rising_edge( plClk ) then
slavmm_rcv_read <= '0';
sl3avmm_rcv_address <= B"000";
slavmm_rcv_write <= '0';
sl32avmm_rcv_writedata <= X"00000000";
case stDualConfigState is
when ST_DUALCONFIG_IDLE =>
if slGoReboot = '1' then
if slToBeErase = '0' then
stDualConfigState <= ST_DUALCONFIG_WRWAIT;
slavmm_rcv_write <= '1';
sl3avmm_rcv_address <= B"001";
sl32avmm_rcv_writedata <= X"00000001"; -- application image(image0)
end if;
if slFaultRetrigger = '1' then
sl32avmm_rcv_writedata <= X"00000003"; -- factory image(image1)
end if;
end if;
if slWatchdogResetFlg = '0' then
slWatchdogResetFlg <= '1';
sl32avmm_rcv_writedata <= X"00000002";
end if;
when ST_DUALCONFIG_WRWAIT =>
stDualConfigState <= ST_DUALCONFIG_READ;
when ST_DUALCONFIG_READ =>
stDualConfigState <= ST_DUALCONFIG_RDWAIT;
slavmm_rcv_read <= '1';
sl3avmm_rcv_address <= B"011";
when ST_DUALCONFIG_RDWAIT =>
stDualConfigState <= ST_DUALCONFIG_TRIGGER;
when ST_DUALCONFIG_TRIGGER =>
if sl32avmm_rcv_readdata(0) = '0' then
stDualConfigState <= ST_DUALCONFIG_TRIGGER_DONE;
end if;
when ST_DUALCONFIG_TRIGGER_DONE =>
null;
when others =>
null;
end case;
end if;
end process;
