After watchdog for dual-config is enabled, the FPGA seems like not work properly every dozens of seconds. Why?
Will the code below OK? But after write sl32avmm_rcv_writedata <= X"00000001"; then FPGA will be reconfiged, I guess FPGA will not receive reset cmd sl32avmm_rcv_writedata <= X"00000002"; How should I set reconfig and watchdog reset in my code? Thanks!@JohnT_Intel
(50Mhz clock)
when ST_DUALCONFIG_TRIGGER =>
slavmm_rcv_read <= '1';
sl3avmm_rcv_address <= B"011";
if sl32avmm_rcv_readdata(0) = '0' then
stDualConfigState <= ST_DUALCONFIG_TRIGGER_DONE;
slavmm_rcv_write <= '1';
sl3avmm_rcv_address <= B"000";
end if;
when ST_DUALCONFIG_TRIGGER_DONE =>
when others =>
null;
end case;
