NikoR's avatar
NikoR
6 years ago
Advanced .jbc files with normal compilation flow
Hi.
From the Programmer Utility you can create an advanced .jbc file from a .pof file. (E.g. program configuration and user flash partitions in Max10)
If you enable .jbc file generation through the Device&Pin Options => Programming Files settings, the .jbc file is generated from the .sof file only and only capable of configuring a Max10.
Is there a way to make an advanced .jbc file as part of the normal compilation flow?
Best regards
Nikolay
  • ShafiqY_Intel's avatar
    ShafiqY_Intel
    Hi Nikolay,
    You can use quartus_cpf command to convert input file (.sof or .pof or .cdf file) to .jbc file.
    Here the example the command:
    • quartus_cpf -c <input_sof_file> <output_jbc_file>
    • quartus_cpf -c <input_pof_file> <output_jbc_file>
    • quartus_cpf -c <input_cdf_file> <output_jbc_file>
    I hope this will help.
    Cheers
    • JChri1's avatar
      JChri1
      Hi Shafiq
      I have tried that and that, both with pof and cdf and it dosn't work. It is as if some option are missing. The messages from the JAM pplayer is also different from when the jbc file is generated be the programmer. The programmer makes more of those DO_*********** (optional)
      jbc generated by quartus_cpf
      CRC matched: CRC value = 0000FC76h
      File format is Jam STAPL ByteCode format
      NOTE "CREATOR" = "QUARTUS PRIME JAM COMPOSER 18.1"
      NOTE "DATE" = "2020/03/05"
      NOTE "DEVICE" = "10M02SC"
      NOTE "NEED_FREQUENCY_CONTROL" = "0"
      NOTE "FILE" = "ctx_mbf7332D201_ic1.pof"
      NOTE "TARGET" = "1"
      NOTE "IDCODE" = "031810DD"
      NOTE "USERCODE" = "000BAF3E"
      NOTE "CHECKSUM" = "006DC5C8"
      NOTE "SAVE_DATA" = "DEVICE_DATA"
      NOTE "SAVE_DATA_VARIABLES" = "V0, A12, A13, A25, A42, A93, A43, A92, A94, A95, A105, A109, A111"
      NOTE "STAPL_VERSION" = "JESD71"
      NOTE "JAM_VERSION" = "2.0"
      NOTE "ALG_VERSION" = "68"
      Actions available in this file:
      PROGRAM
      DO_BLANK_CHECK (optional)
      DO_VERIFY (recommended)
      DO_BYPASS_CFM (optional)
      DO_BYPASS_UFM (optional)
      DO_BYPASS_ICB (optional)
      DO_BYPASS_CFM1 (optional)
      DO_READ_USERCODE (optional)
      BLANKCHECK
      VERIFY
      CONFIGURE
      DO_HALT_ON_CHIP_CC (optional)
      DO_IGNORE_IDCODE_ERRORS (optional)
      DO_IGNORE_INTOSC_BYPASS (recommended)
      DO_BYPASS_SECOND_IDCODE_READ (optional)
      ERASE
      READ_USERCODE
      CHECK_IDCODE
      Device #1 IDCODE is 031810DD
      configuring SRAM device(s)...
      Device programming failure
      Device configuration failure
      jbc generated by programmer
      CRC matched: CRC value = 00003C83h
      NOTE "CREATOR" = "QUARTUS PRIME JAM COMPOSER 16.1"
      NOTE "DATE" = "2020/02/25"
      NOTE "FILE" = "ctx_mbf7332D201_ic1_version_2.pof"
      NOTE "TARGET" = "1"
      NOTE "USERCODE" = "000FA60E"
      NOTE "CHECKSUM" = "00702D4F"
      NOTE "SAVE_DATA_VARIABLES" = "V0, A12, A13, A25, A43, A92, A94, A95, A105, A109, A111"
      NOTE "ALG_VERSION" = "67"
      PROGRAM
      DO_DISABLE_ISP_CLAMP (optional)
      DO_REAL_TIME_ISP (optional)
      DO_FORCE_SRAM_DOWNLOAD (optional)
      DO_INIT_CONFIGURATION (optional)
      BLANKCHECK
      VERIFY
      ERASE
      READ_USERCODE
      CHECK_IDCODE
      full-chip erasing Max 10 FPGA device(s) ...
      programming Max 10 FPGA CFM0 block at sector 5 ...
      programming Max 10 FPGA UFM block at sector 1 ...
      programming Max 10 FPGA UFM block at sector 2 ...
      verifying Max 10 FPGA CFM0 block at sector 5 ...
      verifying Max 10 FPGA UFM block at sector 1 ...
      verifying Max 10 FPGA UFM block at sector 2 ...
      programming Max 10 FPGA DSM block ...
      DONE
        ShafiqY_Intel
        Hi JChri1,
        I send you a forum private message.
        Please follow up there.
    ShafiqY_Intel
    Hi Nikolay,
    You can create .jbc file using Quartus Programmer.
    Add your .pof file. Choose which CFM/UFM you want to program. (My case I choose CFM0 and UFM)
    Then, go to file --> Create JAM, JBC, SVF and ISC file.
    Then, choose .jbc file.
    Cheers.
    • JChri1's avatar
      JChri1
      This is not what Nikolay asked about. He already stated that he knows how to do it using the programmer..
      The question was
      "Is there a way to make an advanced .jbc file as part of the normal compilation flow?"
