NikoR
6 years agoAdvanced .jbc files with normal compilation flow
Hi. From the Programmer Utility you can create an advanced .jbc file from a .pof file. (E.g. program configuration and user flash partitions in Max10) If you enable .jbc file generation through the...
NikoR
6 years agoHi Shafiq.
There is a project assignment that can potentially be used in this case: POST_FLOW_SCRIPT_FILE
The next question is therefore:
What is the tcl/shell command to make the advanced .jbc file as you described above?
Nikolay
