NikoR
6 years agoAdvanced .jbc files with normal compilation flow
Hi. From the Programmer Utility you can create an advanced .jbc file from a .pof file. (E.g. program configuration and user flash partitions in Max10) If you enable .jbc file generation through the...
ShafiqY_Intel
6 years agoHi Nikolay,
You can create .jbc file using Quartus Programmer.
Add your .pof file. Choose which CFM/UFM you want to program. (My case I choose CFM0 and UFM)
Then, go to file --> Create JAM, JBC, SVF and ISC file.
Then, choose .jbc file.
I hope this will help.
Cheers.
- JChri16 years ago
This is not what Nikolay asked about. He already stated that he knows how to do it using the programmer..
The question was
"Is there a way to make an advanced .jbc file as part of the normal compilation flow?"
