17 years agoAdjusting Brightness of NEEK's LCD
Hello All, I wanted to adjust the brightness and contrast of the LCD (800*480) which is there on NEEK using registers. It mentions in the user guide that there is LCD controller interface to c...
17 years agommmmm, ok, here is the link for terasic trdb_ltm module data sheet,
http://www.terasic.com.tw/attachment/archive/213/trdb_ltm_userguide.pdf In page 30 you can find "Register map of the LCD Driver IC" here is the register description for brightness and gamma curve. Compare with alt_tpo_lcd_init function in alt_tpo_lcd.c from example.
