michalis_patelis's avatar
michalis_patelis
3 years ago
adding information regarding expected timing in the LPM_ADD_SUB section of the user guide
To help an engineer make an informed decision about using any of the integer arithmetic IP cores, it would help immensely if some timing information was provides in the user's manual.
taking as an example the LPM_ADD_SUB IP core (page 22 in the manual)
some indication for the expected timing:
- when no pipelining is deifned, what is the expected input-to-output propagation delay for such an IP core? Dependencies on core parameters, target FPGA family, speed grade, etc exist, of course, but some examples for specific families and speed grades would be helpful: for example 8-bit/16-bit/32-bit adder-only in a Cyclone V, speed grade x, etc.
- when pipelining is defined, what is the expected clock frequency that the IP core could operate at? (for dependencies, same as above).
It is understood that such timing information, if available, could only serve as a rough guide to the designer, but they would still be very useful in making a choice between pipelining/non-pipelining and, if pipelined, how many pipe-stages.
  • sstrell's avatar
    sstrell
    As you state, there are just too many possibilities of device and options to put something in a user guide. That's the whole point of the timing analyzer in Quartus. You can add something to a design and then quickly get this information for the device you are targeting with the options you select.
    If something like this was in a user guide, how are you seeing its use for a designer?
    And as for pipelining, well, in theory, you can never have too many pipeline stages if your goal is a fast running design if you are ok in the rest of your design with the extra cycles of latency. This is the whole idea behind hyperflex in Stratix 10 and Agilex. And fast forward compile with those devices will tell you how many pipeline stages would be most optimal.
