14 years ago
Adding and resizing in one step
Is there a way to add two unsigned numbers and extract only the x most significant bits from it in one step?
I want something like this:
sum <= resize(number1 + number2,4)
Instead of:
temp <= number1 + number2
sum <= temp(7 downto 4)
The existing resize function in numeric_std drops the msb's, I want the lsb's dropped.
Thanks in advance!
    If your tool understands and supports the following:
    sum = (num1 + num2)/2**4;
    Then it is equivalent to discarding 4 bits from result unless it goes silly and creates a division module.
    alternatively if you can accept truncation errors then:
    sum <= num1(6 downto 4) + num2(6 downto 4);
    is almost equivalent but division is done on operands.
